With 5000 ANSI lumens brightness this very bright and compact projector is recommended for screen sizes of unto 140" which makes it perfect for mid to large meeting rooms as well as classrooms in higher education.
Thanks to the compact design and large optical zoom of 1.7x, vertical keystone as well as vertical and horizontal keystone you are very flexible in placing the projector in the room without compromising too much on overall design and room integration.
