Thanks to the compact design, large optical zoom of 1.7x, and vertical as well as horizontal keystone correction you are very flexible in placing the projector in the room without compromising too much on overall design and room integration. In addition to remote control and monitoring over wired also content transmission including audio is supported.
With 4500 ANSI lumens brightness this very bright and compact projector is recommended for screen sizes of up to 140" which makes it perfect for mid to large meeting rooms as well as classrooms in higher education.
