Color accuracy that you can trust. The 27" MultiSync PA272W is the benchmark desktop display for color accurate applications. The GB-R LED backlight provides 99.3% coverage of the Adobe RGB color space while consuming up to 37% less power than comparable CCFL backlights. Utilizing a high performance AH-IPS LCD panel, the MultiSync PA272W will reliably deliver high quality, accurate images simply and beautifully.
