State-of-the-art professional public displays with highest standards in reliability and variability - for all kinds of digital signage applications.
NEC MultiSync P521 52" LCD flat panel display - Full HD
Diagonal Class
52"
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i
Video Interface
Component, composite, HDMI, S-Video, SCART
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), HDMI, DisplayPort
HDCP Compatible
S-PVA
Image Aspect Ratio
16:9
TV Tuner
No tuner
Sound Output Mode
Stereo
Speaker System
Speakers not included
Remote control
Microsoft Certification
Certified for Windows Vista
Voltage
290 Watt
120 cm x 14.8 cm x 69.6 cm
40 kg
3-year warranty
290 Watt
Diagonal Class
52"
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Ambient light sensor (ALS), temperature sensor
Video Interface
HDMI Ports Qty
1 ports
PC Interface
HDCP Compatible
Dimensions
Without stand
120 cm
14.8 cm
69.6 cm
40 kg
Enclosure Colour
Display
LCD Display Technology
S-PVA
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Colour Depth
16.7 million colours
Image Contrast Ratio
2000:1
Brightness
700 cd/m²
Widescreen Modes
16:9
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.6 x 0.6mm
Response Time
8 ms
Max V-Sync Rate
85 Hz
Max H-Sync Rate
91.1 kHz
Colour Temperature Control
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
16:9 Mode
Analogue Video Input Signals
NTSC, PAL, SECAM
Input Video Formats
Supported Computer Resolutions
1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 720 x 400, 1360 x 768, 1920 x 1080
Remote Control
Remote control
Audio System
Sound Output Mode
Stereo
Speaker System
External Speakers Amplifier Power (Total)
30 Watt
Connector Type
DisplayPort , HDMI , DVI-Digital , VGA input , RGB input , Component video input , Composite video input , Composite video input , S-Video input , RGB output , Composite video output , 2 x audio line-in , 2 x serial , Speakers output , Audio line-out , Audio line-in
Expansion Slots
1 x Expansion Slot
VGA cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, CSA, UL, TUV GS, VCCI, C-Tick, cUL, DDC-2Bi, VESA DPMS, CCC, PSB, RoHS
