The PRO Series motherboards fit in any PC. Quality you can trust with top performance and clever business solutions are key aspects of these motherboards. Make your life easier and boost your business with the super stable, reliable and long-lasting PRO Series motherboards.
OC Genie is the world's first built-in hardware overclocking technology on motherboards. With this one-second overclocking option we're giving you even more performance. Just hit the button and your PC gets another adrenalin shot. Delivering up to 20% of free extra performance for the CPU and memory.
MSI EZ debug LED is an easy troubleshooting tool built with 3 LEDs to indicate to CPU/memory/VGA operation every time you boot up your system. Run into trouble? Use the LEDs to easily identify the item causing problems.
