Quicklinx: | BGYQWS00 |
Mfr#: | X99A GODLIKE GAMING |
MORE SPEED, MORE BANDWIDTH, LESS POWER CONSUMPTION
MSI® engineers made sure you can enjoy high speed DDR4 frequency and the best memory compatibility. DDR4 brings higher memory speeds at even lower power usage as low as 1.2v. With 8 memory slots available, MSI supports larger memory configurations up to 128GB.
DDR4 4351 MHz
Taking numerous world records in DDR4 frequency, MSI motherboards have proven great compatibility and performance since the introduction of DDR4 memory.
Mystic Light
Customize and set up your own color scheme with Mystic Light. Make your build look on fire or cold as ice. You are in control. You can select any of the colors from the palette to match your systems’ design. Tired of always the same color? Just change it to another one using the easy to use Mystic Light APP available on PC, phone and tablet, and make your PC look & feel brand new!
GODLIKE DESIGN WITH HEAVY PLATED ARMOR
The MSI® X99 GODLIKE GAMING motherboard is designed to provide gamers with best-in-class features and technology. To cool, protect and highlight these features, heavy plated armor is used. Stunning looks, backed by the MSI Dragon, the X99A GODLIKE GAMING motherboard is an engineering masterpiece tailored to gaming perfection.
DRAGON COVER
The Dragon cover doesn't just look cool with its GODLIKE branding, it also protects I/O devices against Electro Magnetic Interference, ensuring pure signals.
EXTENDED DRAGON ARMOR
This awesome looking protective shield helps to keep the audio signal pure, preventing interference from other components.
Enhanced heatPIPES
Designed to withstand anything, the heatsinks found on this motherboard truly represent style & performance.
DRAGON HEATSINK
Heavy plated armor makes sure your system stays cool during even the longest gaming sessions or extreme overclocking.
KILLER™ DOUBLE SHOT-X3 PRO
Killer™ DoubleShot-X3 Pro allows the 2x Killer™ Ethernet connectors and the Killer™ Wi-Fi adapter to work together for the ultimate high speed attack. The Killer Network Manager decides which apps runs on which connection for gaming traffic optimization. This will give you the max throughput as high as 2.867 Gbps.
Killer™ WIRELESS AC 1535 with ExtremeRANGE™
Killer™ Wireless-AC 1535 with ExtremeRange™ Technology delivers industry-leading speed, intelligence and control for PCs. Killer’s Lag and Latency ReductionTM Technology combined with Killer’s ExtremeRange™ Technology revolutionizes the user experience by driving better throughput, lower latencies, and longer WiFi ranges. Play your game, stream your game, and enjoy your HD video – all at the same time and uninterrupted.
Benefits
