With high definition audio (8-channel) and Realtek ALC1220 Audio Codec, the MSI X370 GAMING PRO motherboard delivers a rich, immersive sound experience. This feature, complemented by Nahimic 2 Sound Technology, ensures clear, crisp audio for gaming, music, and movies.
Robust expansion options
Offering a wide range of expansion slots including 4 DIMM 288-pin for RAM, 2 PCIe 3.0 x16, and additional PCIe 2.0 slots, the motherboard supports extensive upgrade possibilities. Whether for gaming, content creation, or multitasking, these slots accommodate various components to enhance your system's performance.
Versatile connectivity
The motherboard features a comprehensive suite of interfaces including USB 3.1 Gen 1 and Gen 2, USB-C Gen2, and Gigabit Ethernet for high-speed data transfer and reliable Internet connections. HDMI and DVI-D outputs cater to diverse display needs, ensuring compatibility with a wide range of monitors and projectors.
Advanced storage solutions
With support for M.2 socket and Serial ATA-600 (RAID), the MSI X370 GAMING PRO allows for fast data access and storage flexibility. The inclusion of 6 x SATA-600 ports and 2 x M.2 slots enables high-speed storage configurations, optimizing your system for quick boot times and rapid application loading.
Durable and reliable
Built with MSI Military Class IV components, the motherboard promises durability and reliability under various conditions. Features like Double ESD Protection, LAN Protect, and MSI Steel Armor safeguard the system against electrical surges and physical damage, ensuring a long-lasting computing experience.
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (x16/x0, x8/x8 mode (with AMD Ryzen CPU); x8/x0 mode (with AMD 7th Generation A-series/Athlon CPU)) , 3 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode (auto turn-off if M.2 is occupied))
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2
1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x USB-C Gen2 , 1 x USB 3.1 Gen 2 , 1 x HDMI , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 2 x USB 2.0 , 1 x DVI-D , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
MSI ClickBIOS 5
Hardware Features
NVIDIA 2-way SLI Technology Support, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, MSI Military Class IV, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Game Boost, LAN Protect, Double ESD Protection, MSI Audio Boost 4, Nahimic 2 Sound Technology
Software Included
MSI Live Update, MSI Command Center, RAMdisk, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI X-BOOST
