MSI AMD Radeon R7 370 GAMING 4G
Product Specification
Model Name - R7 370 GAMING 4G
Model - V305
GPU - AMD Radeon™ R7 370
Codename - Trinidad
Processors - 1024 Units
Core Boost/ Base Clock (OC) - 1070 / 1020 MHz
Memory Clock (OC) - 5700 MHz
Memory Size - 4GB GDDR5
Memory Bus - 256 bits
Output - DisplayPort/HDMI/DL-DVI-I/DL-DVI-D
Power Consumption/Connector - 110 W / 6-pin x1
Dimension / Weight - 258x132x37 mm / 632 g
Form Factor - ATX
With every new generation of GPUs comes more performance. With every new
generation of MSI TWIN FROZR we give you less noise and heat!
TWIN FROZR V Thermal Design - 18 months in the development to ensure the
cards have the quality and stability to give you the FPS you need. TORX Fan
Blades - Maximizes downwards airflow and air dispersion to the massive
heatsink below. Airflow Control Technology - Guides more airflow directly
onto the heatpipes by using special deflectors on the heatsink. SuperSU Pipe
Architecture - A massive nickel-plated copper base plate connected to 8mm
heatpipes on the Graphics Card. ZERO FROZR Technology - Eliminates fan noise
in low-load situations by stopping the fans when they are not needed.
Independent Fan Control Software - The two fans can work independently of
each other. Premium White LED Controllable Lighting - Allows you to choose
from 5 unique modes to set the right ambience for your gaming moments. MSI
Afterburner GPU Overclocking Tool - The world's favourite cross-vendor GPU
overclocking software. MSI GAMING APP - Overclocking through this app is
covered by warranty to take away your worries. TWIN FROZR V
Cooler, Quieter, Better Gaming
We've listened to all your requests and the new TWIN FROZR V is smaller,
features stronger fans, generates less noise, keeps your graphics card and
its components cooler and matches perfectly with your MSI GAMING motherboard
including some funky LED lightning. Our new TORX fans generates more airflow
to maximize air dissipation to heatsink, while the advanced dispersion blade
design generates 19% more airflow without increasing drag for supreme silent
performance.
AIRFLOW CONTROL
Enhanced Dissipation Efficiency
MSI has fitted TWIN FROZR V coolers with the all new Airflow Control
technology which guides more airflow directly onto the heat pipes by using
special deflectors on the heat sink. In addition, this exclusive heat sink
design increases heat sink surface area, greatly enhancing the dissipation
efficiency.
SuperSU PIPE
SuperSU Architecture is the best cooling solution for graphics cards. The
GPU is cooled by a massive nickel-plated copper base plate connected to
Super Pipes (8mm heat pipes) on the MSI GAMING series graphics card.
Additionally, the new heat pipe layout increases efficiency by reducing the
length of unused heat pipe and a special SU-form design.
ZERO FROZR
Smart Cooling, Stay Quiet
MSI's TWIN FROZR V Thermal Designs are equipped with Zero Frozr technology
which was first introduced by MSI back in 2008. Zero Frozr technology
eliminates fan noise in low-load situations by stopping the fans when they
are not needed. Compared to other graphics cards, there is no continuous hum
of airflow to tell you there's a powerful graphics card in your gaming rig.
This means you can focus on gaming without the distraction of other sounds
coming from your PC.
INDEPENDENT FAN CONTROL
Maximum Fan Control, Minimum Noise
The two fans on the TWIN FROZR V Thermal Design can work independently of
each other*. This means you'll only have the necessary fan noise given the
temperature of the components below the fan. This unique solution gives you
the best balance between temperatures and noise and highlights why the MSI
TWIN FROZR V is seen as the ultimate Graphics Card cooling solution.
*Availability of this feature varies by model.
CATCHING THE VIBE WITH COOL LED EFFECTS
White LED Lighting
Featuring a premium LED illuminated MSI GAMING Dragon to lighten the mood.
This brand new function allows you to choose from 5 unique modes to set the
right ambience for your gaming moments with just one click using the MSI
GAMING APP or control it from the NVIDIA GeForce Experience software.
