Visualize your victory with MSI Optix G273QF esports gaming monitor. Equipped with a fast refresh rate, 1 ms GTG response time panel, Optix G273QF will give you the competitive edge you need to take down your opponents.
Rapid IPS display provides gamers with an ultrafast 1 ms GTG response time, which will significantly reduce monitor blur occurrence. The crystal-clear image will certainly give you a competitive edge for precise decisions in fast-moving games.
Age crossing technological breakthrough
The liquid crystal molecules of Rapid IPS display rotate as fast as the tornado. With the speed going faster than normal liquid crystal molecules, the response time can be shortened to 1 ms GTG to eliminate monitor blur and provide crystal clear images.
View wider, fight better
The Optix gaming monitor features the WQHD panel. This panel allows gamers to examine bigger game scenes compared to other traditional Full HD panels, and put them ahead of other competitors.
This is color
Optix series gaming monitor is equipped with the IPS panel that produces no image distortion and minimum color shifts when viewed from different angles. Additionally, the IPS panel will offer clear images and instantly optimize screen color and brightness to ensure that you enjoy every scene at its best.
165 Hz refresh rate + 1 ms GTG response time
The Optix monitor is equipped with the 165 Hz refresh rate and 1 ms GTG response time panel which has the benefit in fast moving game genres such as first-person shooters, fighters, racing sims, real-time strategy, and sports. This type of games requires very fast and precise movements, which an ultrahigh refresh rate and fast response time monitor will put you ahead of your competition.
Night vision engaged
Whether your entire screen is dark, or just a few portions have heavy shadows. Let the smart black tuner brighten your day by bringing out the fine details in dark areas.
Tailored for the perfect fit
The MSI Optix gaming monitor is built to make you as comfortable as possible while gaming. Through adjustments of tilting, you can easily change the position of the monitor for maximum ergonomics and optimum viewing experiences.
From edge to edge
With a super-narrow bezel, enjoy better immersion with a multimonitor 180-degree setup. Enjoy better continuity between screens while playing games, working, or general computing.
Anti-Flicker technology
MSI Anti-Flicker technology provides a very comfortable viewing experience by reducing the amount of flicker.
Blue light reduction
The Optix monitor is optimized to produce less amount of blue light displayed by the monitor, so that you can game for longer periods of time without eye-fatigue.
MSI Optix G273QF - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/397299
Energy Class
Class G
Power Consumption (On mode)
32 W
5-way joystick
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440 (DisplayPort: 165 Hz, HDMI: 144 Hz)
