Making your life easier is our business
The PRO Series motherboards fit in any PC. Quality you can trust with top performance and clever business solutions are key aspects of these motherboards. Make your life easier and boost your business with the super stable, reliable and long-lasting PRO Series motherboards.
CPU support - 6th Gen Intel® Core™ / Pentium® / Celeron® processors
CPU socket LGA 1151
Chipset Intel® H170 Chipset
Graphics interface - 1 x PCI-E 3.0 x16
Display interface - HDMI, DVI-D, VGA – Requires Processor Graphics
Memory support - 4 DIMMs, Dual Channel DDR4-2133 MHz
Expansion slots - 2 x PCI-E x1
SATA - 6 x SATA 6 Gb/s (2 x ports from SATA Express port)
SATA RAID - RAID 0, 1, 5, 10 – Available on SATA1 to SATA6
USB - 6 x USB 3.1 Gen1, 6 x USB 2.0
LAN - Realtek® Gigabit Ethernet
Audio - 8-channel(7.1) HD Audio with Audio Boost
Others - COM / LPT pin header
