Quicklinx: | BVHGWS00 |
Mfr#: | 9S7-178211-612 |
MSI exclusive Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. One click on the fan boost button, a total of 6 heat pipes and dual fans actively and effectively push heat out of the system. MSI True Color technology guarantees that each panel in MSI notebook provides fine precision in color. Hence, each color is delivered with high standard precision in detail, guaranteeing excellent color fidelity for many use applications. Expand the vision for extreme gaming experience. Embrace immersive gaming experience by expanding your gaming real estate across 3 external displays. MSI gaming notebook built in high quality wide-view angle display takes image clarity to a high level with higher pixel resolution. Images are more sharp and vivid in contrast level and clearer in brightness level. Hence, images are more vivid even from left and right side of the viewing angle. When you're playing games, you will have breathtaking and brilliantly true-to-life viewing experience.
Push the limits of your audio peripherals and hear the difference with the SABRE audio DAC. Discover details that you've been missing or maintain the upper-hand in competitive FPS matches where every bit of sound counts. Originally developed for military fighter jets, Nahimic specializes in 3D sound software processing and audio improvements offering virtual 7.1 sound in immersive high definition. Designed to work with standard audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high definition audio recorder to easily capture and stream studio quality sound. The GT72 is packing advanced Dynaudio design with 2 channels with 1 subwoofer, and its absolutely authentic hearing experience. People who play games or enjoy movies will absolutely be immersed in the perfect system with outstanding sound effect.
Every hardware detail of this keyboard is calculated and especially designed for professional gamers' needs. Better responsive and tactile feedback, optimum WASD zone and support of multi-key inputs are all for gamers to gain full command over gaming missions. Stop losing games to lag with Killer DoubleShot Pro. Protect and prioritize networking traffic while preventing lag spikes so you can game without fear and play at your best. Select programs you want your network to prioritize to ensure maximum bandwidth and track your speeds. Killer DoubleShot Pro supports both Killer Gb LAN and Wi-Fi 802.11ac dual band protocol and improves average latency.
