            NVIDIA GEFORCE RTX 4060 TI GPU - The 4060 Ti features advanced Ada Lovelace architecture for superior 3rd gen RTX ray-tracing capabilities (1080p) & comes with 16GB of GDDR6 memory (18 Gbps); DLSS 3.0 enhanced frame rate performance supported
MSI VENTUS EDGE - The RTX 4060 Ti VENTUS 3X 16G OC is a factory-overclocked GPU variant of the RTX 4060 Ti VENTUS 3X 16G; This is an enhanced option for gamers & creators looking for a graphics card with an optimal value-to-performance ratio
TRIPLE TORX FAN 4.0 COOLING - TORX Fan 4.0 technology features paired blades, ZERO FROZR (0 RPM mode); A nickel-plated copper baseplate, heat pipes and an Airflow Control heatsink
SPARTAN DESIGN - A sturdy backplate with flow-through design reinforce the chassis, while internally an enhanced PCB includes premium electrical safeguards
FUNDAMENTAL & EFFICIENT - The 2.1 slot card (PCIe 4.0 x16) is 308 mm long, weighs 757 grams & has a recommended PSU wattage of 550 or higher (8-pin, 165W power consumption); Rear ports include 3 x DisplayPort 1.4a & 1 x HDMI 2.1 (4K/120Hz)
