Ti. The most powerful two letters in the world of GPUs. When paired with NVIDIAs flagship gaming GPU – GeForce GTX 980 – it enables new levels of performance and capabilities. Accelerated by the groundbreaking NVIDIA Maxwell™ architecture, GTX 980 Ti delivers an unbeatable 4K and virtual reality experience. With 2816 NVIDIA® CUDA® cores and 6 GB of memory, it has the horsepower to drive whatever comes next.
Core/Memory
• Boost Clock / Base Clock
• 1190 MHz / 1102 MHz
• 6144 MB GDDR5 / 7010 MHz Memory
Video Output Function
• Dual-link DVI-I x 1
• DisplayPort x 3
• HDMI x 1
Armor 2X Thermal Design
Delivers more airflow than traditional single fan thermal design.
Huge heat sink provides better heat dissipation.
Propeller Blade Technology
Produce 20% more airflow than traditional fan design.
Produces less noise than traditional fan designs.
Airflow Control technology
Deflects more airflow to heatpipes and improves airflow efficiency.
Increases the heatsink area to enhance dissipation efficiency.
Military Class 4 Components
Certified to MIL-STD-810G standards for top stability and quality.
Built with Hi-c CAP, Solid CAP, and New SFC components.
