Product Specification
- Model Name GTX 970 GAMING
- GPU NVIDIA GeForce GTX 970
- CUDA Core 1664 Units
- Core Base Clock (OC) 1140MHz
- Core Boost Clock (OC) 1279MHz
- Memory Clock 7000 MHz
- Memory Size 4GB GDDR5
- Memory Bus 256 bits
- Output: DL-DVI-I/DL-DVI-D DisplayPort/HDMI Power Consumption 148W
- Card Dimension 269x141x35 mm
- Form Factor ATX
- 3 Year Warranty
MSI GeForce GTX 970 OC Edition Gaming Card
As far as high performance graphics cards go the GeForce GTX 970 is one of the best value cards around. NVIDIA has combined its latest Maxwell graphics technology with 4GB of video memory to easily power your HD monitors. The efficient MSI GTX 970 GAMING 4G can offer excellent gaming performance for an affordable price.
Airflow Control Technology
The Twin Frozr V Coolers have been fitted with the all new Airflow Control Technology from MSI which guides more airflow directly onto the heat pipes. The way it does this is by using special deflectors on the heat sink, this exclusive heat sink design increases the surface area, greatly enhancing the efficiency of the cooler.
Torx Fan
The Torx Fans for the Twin Frozr V have been designed to house there two types of fan blades, Firstly is the Traditional Fan Blade which maximizes downwards airflow and air dispersion to the massive heat sink below, the second is the Dispersion Fan Blade that generates more airflow to maximise the lateral dissipation to the heat sink.
SuperSU Pipe Architecture
The SuperSU Architecture is one of the best cooling solution available for graphics cards. On MSI GAMING series graphics cards the GPU is cooled by a massive nickel-plated copper base plate connected to Super Pipes (8mm heat pipes). Additionally, the new heat pipe layout increases efficiency by reducing the length of unused heat pipe and a special SU-form design.
Zero Frozr
The technology for Zero Frozr was first introduced by MSI back in 2008 and is now equipped on the latest MSI Twin Frozr V thermal design. In low-load situations Zero Frozr technology eliminates fan noise by stopping the fans when they are not needed. Compared to other graphics cards, there is no continuous hum of airflow this means you can focus on gaming without the distraction of other sounds coming from your PC.
