Military Class 4 is the next step in high quality components. The Dark Choke and Solid CAP will make sure that your PC runs more stable under extreme gaming conditions.
Humidity protection
The Gen 4 Fabric PCB helps to against moisture cause by some humid conditions and environments.
EMI protection
The optimized EMI-proof design helps to keep users safe when during a long-time computer operation.
ESD protection
Anti-ESD ICs and fuses onboard helps to totally protect your motherboard from electrostatic damage.
High temperature protection
Certificated Military Class 4 components help to work stable under some extreme conditions.
OC Genie 4
Just hit the button and your PC gets another adrenalin shot straight away. Give your system an awesome performance boost with ease.
Fast Boot
No more seamless waiting for your O/S to be loaded! MSI Fast Boot helps to make your system boot lightning fast. MSI Fast Boot also features a GO2BIOS button. Simply click it to restart your PC and go straight to the system BIOS.
M-Flash
Compared to common motherboards which need extra BIOS chips, MSI's M-Flash has a double advantage which doesn't need extra components and secondly, all your BIOS data will be saved in the USB drive. The stored data does not only have backup and upgrade function, moreover, it can also be seen as a portable BIOS chip which is actually able to boot up your PC.
MSI A88XI AC V2 - motherboard - mini ITX - Socket FM2+ - AMD A88X
Motherboard - mini ITX
Chipset Type
AMD A88X
Processor Socket
1 x Socket FM2+
Compatible Processors
Athlon, A series
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Realtek RTL8111G / Intel Dual Band Wireless-AC 7260
Network Interfaces
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 (FM2+ processor must be installed) , 1 x Mini PCIe
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x PS/2 keyboard / mouse , 1 x HDMI , 1 x VGA , 1 x DVI-D , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
M-Flash, MSI ClickBIOS 4
Hardware Features
AMD Cool 'n' Quiet Technology, USB Safeguard, Intel Extreme Memory Profile (XMP) support, Super Charger, AMD Radeon Dual Graphics, AMD Memory Profile (AMP) support, MSI Military Class IV, Military Class Essentials, OC Genie 4, MSI Fast Boot, 4K Ultra HD ready
