The MSI Adora all-in-one PC is designed with three key values in mind: simple, stylish and intuitive. In order to meet these values, the Adora features a solid and ultra slim chassis, topping mere 21 mm at its thick point. With a smooth surface, emphasized by a beautiful frameless display, the Adora fits into every modern living room or office. The frameless design also makes the Adora more durable, dust and scratch resistant than traditional frame exteriors.
Flicker-Free all-in-one PC
According to medical research, the average flickering rate of conventional monitors is 200 times/second. This means that your eyes will suffer from over 5 million flicker times in a standard 8 hour working day, which can result in computer vision syndrome. The Flicker-Free technology integrated into the Adora display stabilizes the power current and prevents flickering invisible to the naked eye under normal conditions. When used for extended periods of time, it effectively reduces eyestrain while also improving productivity.
Blue light control
Blue light is light with wavelengths in the 381 nm to 500 nm range. This can be dangerous to the human eye, causing cataract and retinal degeneration. The flicker-free display of the MSI Adora all-in-one PC effectively reduces blue light.
Reward your ears with Sound Blaster Cinema
Sound Blaster Cinema is designed to bring the same great audio experience found in live performances, films, and recording studios - to the PC. Powered by the SBX Pro Studio technologies, the Sound Blaster Cinema delivers a much more realistic and immersive experience. Thanks to Sound Blaster Cinema, you're also getting amazing surround sound with just stereo headphones. The most beautiful sound effects are reproduced crystal adoraclear allowing you to truly dive into your favorite music, video or gaming activities.
Full HD display
With a display that can support Full HD 1080p, you are sure to be able to watch the latest movies and videos in high definition, with the clearest and crispest details.
Instant Display technology
The exclusively developed MSI Instant Display technology allows the screen to enter the "standby" mode when the all-in-one PC is turned on and connected to an external display via the HDMI input port, without the need to press the power button on the unit.
