Trusted security & easy manageability
Your business data and mobile platforms are secured by ThinkShield® for mobile. AI-based defence systems, government-grade certifications, trusted suppliers, vetted manufacturing processes, and a dedicated incident-response team deliver 360° protection.
Deploy ThinkPhone right out of the box with zero-touch enrolment. Manage your entire fleet from a single location and create a customised experience for your organisation.
Kept in confidence
Device hardware, firmware, and software are integrated to protect your most sensitive data from mobile threats. With Moto KeySafe, PINs, passwords, and cryptographic keys are isolated from other device data for an added layer of high-level security.
Built for where your business takes you
Take whatever work throws at you with impact-resistant Gorilla® Glass Victus™ display protection. MIL STD 810H-tested1 for durability, ThinkPhone is crafted from aramid fibre that is stronger and lighter than steel, with an aircraft-grade aluminium frame. It’s also IP68-certified to withstand dust, dirt, sand, and submersion in shallow water
ThinkPad's perfect companion
Expand your mobile workspace and enjoy seamless connection to your PC with ThinkPhone. Integrating Android and Microsoft Windows experiences, your organisation can take productivity to new heights. Just double tap the iconic Red Key to easily sync to your ThinkPad or PC. You can even customise a single tap to open any app you choose.
App Streaming
Make your mobile experience part of your desktop experience. Open mobile apps directly on your PC for easy platform integration.
File Drop
Transferring files between ThinkPhone and your PC is as simple as dragging and dropping.
Advanced Webcam
Stay front, centre, and looking sharp on video calls with AI-informed, movement-tracking camera capabilities.
Unified Notifications
Phone notifications appear instantly in the Windows Action centre, so you can answer a call or reply to messages right from your PC.
