Need even more battery power for your iPhone? The Mophie Juice Pack Plus extends the battery life of your iPhone for hours! The Juice Pack Plus also provides a comfortable ergonomic design with the complete protection of a dual-injected hard shell case with protective rubberized band.
The Juice Pack Plus for iPhone combines rechargeable external battery power concealed inside of a protective form-fitting case. It offers the full protection of a hard-shell case with an ultra-thin, light-weight, low-profile design and shock-resistant band.
Features a simple toggle switch allows for standby and charging mode so you only have to use the Juice Pack Plus battery when you need it! Charge and sync your iPhone to iTunes without removing it from the Juice Pack Plus by using the included USB cable. The integrated LED status indicator on the bottom tells you exactly how much "juice" is left at the push of a button. It also indicates the charging status so you know before you go.
