Game loud and clear with the Xbox Wireless Headset, featuring enhanced auto-mute and voice isolation for crystal-clear chat, intuitive design, plus direct pairing to your console, PC, or phone.
- Game loud and clear with the Xbox Wireless Headset, featuring enhanced auto-mute and voice isolation for crystal-clear chat, intuitive design, plus direct pairing to your console, PC, or phone
- Surround yourself with spatial audio technologies including Windows Sonic, Dolby Atmos, and DTS Headphone:X*
- Dive into sound reimagined. Revealing depth, clarity, and details like never before, Dolby Atmos is a sound experience you can feel all around you.
- Enjoy up to 20 hours of battery life with the internal, rechargeable battery
- Be heard clearly with enhanced auto-mute and voice isolation that reduce background noise for crystal-clear chat
- Experience the flexible, lightweight design with an adjustable headband that provides a more comfortable experience during extended play sessions
- Rotate the earcup dials for a quick, intuitive way to adjust volume and game/chat balance
- Fine-tune your headset with the Xbox Accessories app for a customized audio experience*
- Pair directly to your console with Xbox Wireless radio without the need for dongles or a base station
- Connect to your PC or mobile device with Bluetooth® for on-the-go music or chat – even pair to your phone and Xbox simultaneously to chat with a friend on your phone while playing on your console
*See xbox.com/headset-compatibility. Audio customization available via the Xbox Accessories app for Xbox Series X|S, Xbox One, and Windows 10/11 devices. Dolby Atmos and DTS:X: may require additional purchases, app downloads, and supported hardware. Battery life varies significantly with distance from console, additional accessories, usage and other factors. Testing conducted by Microsoft using pre-production units.
Used stock
All used stock comes with a 90 day warranty.
Condition: Customer return - item has been repaired under warranty by the manufacturer
Please note: The box is damaged however the product is in perfect condition.
Ref: HX52 051396
- Accessories:This part of the stock item is present and in good condition
- Packaging:This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- Functional:This part of the stock item is present and in good condition
- Software:This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- Manuals:This part of the stock item is present and in good condition
Condition: Customer return - item has been used and shows signs of use
Ref: HX52 051377
- Packaging:This part of the stock item is present and in good condition
- Software:This part of the stock item is not present or functional
- Manuals:This part of the stock item is not present or functional
