Experience the modernized design of the Xbox Wireless Controller, featuring sculpted surfaces and refined geometry for enhanced comfort during gameplay. Stay on target with a hybrid D-pad and textured grip on the triggers, bumpers, and back case. With the included Xbox Wireless Adapter, you can connect up to 8 Xbox Wireless Controllers at once and play games together wirelessly on Windows PC.
Experience the modernised design of the Xbox Wireless Controller – Carbon Black, featuring sculpted surfaces and refined geometry for enhanced comfort during gameplay. Stay on target with a hybrid D-pad and textured grip on the triggers, bumpers, and back case. Seamlessly capture and share content such as screenshots, recordings, and more with the new Share button. Use the Xbox Accessories app to remap buttons and create custom controller profiles for your favourite games. Quickly pair with, play on, and switch between devices including Xbox Series X, Xbox One, Windows 10 PCs and Android, iOS support coming in the future. Plug in any compatible headset with the 3.5mm audio jack.*
Elevate your game
Experience the modernised design of the Xbox Wireless Controller – Carbon Black, featuring sculpted surfaces and refined geometry for enhanced comfort and effortless control during gameplay.
Custom mapping
Make the controller your own by customising button mapping.* Plus, plug in any compatible headset with the 3.5mm audio headset jack.
Xbox Wireless and Bluetooth® technology
Includes Xbox Wireless and Bluetooth® technology for wireless gaming on supported consoles, Windows 10 PCs and Android phones and tablets. *iOS support coming in the future.
Stay on target
Stay on target with textured grip on the triggers, bumpers, and back case and with a new hybrid D-pad for accurate, yet familiar input.
Share button
Easily pair and switch
Easily pair and switch between devices including Xbox Series X, Xbox One, Windows 10 PCs and Android. *iOS support coming in the future.
*Important information: Compatible with select devices and operating system versions; learn more at xbox.com/controller-compatibility. Battery life varies significantly with headsets, additional accessories, usage, and other factors. Testing conducted by Microsoft using standard AA batteries in preproduction units. Button mapping available via Xbox Accessories app for Xbox Series X|S, Xbox One, and Windows 10/11; app for Windows requires compatible USB-C cable (sold separately).
Windows 10/11: Requires Bluetooth, compatible USB-C® cable, or Xbox Wireless adapter. Each sold separately. Android, iOS, & Bluetooth: Select devices and versions. Some functionality not supported. Software download may be required via Windows PC or console. See xbox.com/controller-compatibility. Use with controller compatible games. You must accept the Warranty & Agreement at xbox.com/warranty and Software License Agreement at xbox.com/slt.
