Microsoft BlueTrack technology combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.
Plug-and-go Nano transceiver
Leave the Nano transceiver plugged in when you're on the go, or stow it in the mouse.
2.4 GHz reliable wireless
Microsoft 2.4 GHz wireless delivers a reliable connection with up to a 30-foot range, with virtually no interference.
10-month battery life
Use your mouse without power interruption for up to 10 months on a single battery. Battery status indicator tells you when battery power is low.
4-way scrolling
Scroll four ways for greater efficiency and comfort with tilt wheel technology.
4 customizable buttons
Get quick access to the media, programs, and files you use most often with customizable buttons.
Microsoft Wireless Mobile Mouse 4000 - mouse - 2.4 GHz - graphite
Mouse
Packaged Quantity
5 (specifications are for single item)
Wireless - 2.4 GHz
Graphite
6.1 cm x 10.3 cm
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
4
Programmable buttons, scrolling 4-way button, Microsoft BlueTrack Technology, Flip 3D button
1 x AA type
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.4.x - 10.5.x
Microsoft Certification
Compatible with Windows 7
3-year warranty
Packaged Quantity
Mouse
Wireless Receiver
6.1 cm
10.3 cm
Graphite
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 9.1 m
Optical
Buttons Qty
4
1 x USB - 4 pin USB Type A
AA type
Alkaline
Installed Qty
1
Run Time (Up To)
10 months
