Fully redesigned, the Surface Pro 4 Type Cover is thinner and lighter than before with improved magnetic stability for lap use. It also has a mechanical keyboard with optimal key spacing for fast and fluid typing, plus an enlarged track pad for precision control and navigation.
Full-laptop experience
Surface Pro 4 Type Cover has an improved design with slightly spread out keys for a more familiar and efficient typing experience. The two-button trackpad is now larger for precision control and navigation.
Work the way you want
The keyboard is sturdy with enhanced magnetic stability along the fold, so you can adjust it to the right angle and work on your lap, on the plane, or at your desk. Since it's designed just for Surface, the Surface Pro 4 Type Cover easily clicks into place to go from tablet to laptop instantly.
Protective and productive
Fold Surface Pro 4 Type Cover back like a magazine for a tablet experience with Surface Pro 4. The keys are disabled when the cover is flipped back to avoid inadvertent typing. When you close Surface Pro 4 Type Cover over the display, it functions as a protective shell, shielding the screen from bumps and scratches.
Make it yours
Surface Pro 4 Type Cover is made from premium materials and feels soft to the touch yet sturdy and quieter when typing. Plus Surface Pro 4 Type Cover is backlit, so you can continue working after the lights go out.
Microsoft Surface Pro 4 Type Cover - keyboard - with trackpad, accelerometer - QWERTY - UK - red
