Bump labels come in four shape and colors, for a total of 16 labels. Shape variations are a solid dot, an open circle, a dash line, and an X.
Keycap labels
Keycap labels are designed to help you identify keys on your keyboard. The labels are transparent with a raised feature on them. The labels can be applied by hand or with the applicator that's attached to the keycap card in the lower right. Using the applicator can help you align the labels to the keyboard keys more consistently.
Port labels
The port labels are designed to help identify and match cables and ports on your device. There are five different port label pairs, for 10 total labels. Each pair is a different color and has a different tactile design so they can be identified visually and by touch.
Opener support
There are two opener supports. The first support has a larger loop, designed to assist in opening a laptop lid. Place the opener support on the edge of the lid with the loop hanging off. The second support has a flexible section in the middle where you can attach a lanyard or wrist strap.
Microsoft Surface Adaptive Kit - notebook accessories bundle
Microsoft Number Pad, Surface Dock 2; Surface Book 3, Go, Go 2, Go 3, Laptop 3, Laptop 4, Laptop 5, Laptop Go 2, Laptop Studio, Pro 7, Pro 7+, Pro 8, Pro 9, Pro X, Studio 2+ for Business
Microsoft Number Pad, Surface Dock 2 , Microsoft Surface Book 3, Go, Go 2, Go 3, Laptop 3, Laptop 4, Laptop 5, Laptop Go 2, Laptop Studio, Pro 7, Pro 7+, Pro 8, Pro 9, Pro X, Studio 2+ for Business
