Professionally design for superb Hi-Fi performance. Microlab FineCone series multimedia speakers select the stunning V12 speaker unit which is designed by Denmark famous speaker designer Peter Larsen, handing down Denmark style to recreate the purest sound.
Microlab premier range, the FC series is based on the FINE CONE designed by Acoustic expert, Peter Larsen.
This design follows strict discipline in speaker designs to achieve perfect linear frequency response curve. Ideal home theater system in all natural wood finish.
Uncolored audio, precise position, and high resolution with Microlab own eAirbass technology
Features:
Powerful 5.1 surround subwoofer system with full range acoustic production and cabinet satellites
eAirbass design, Microlab own proprietory technology - Bass with natural depth and range
6.5" woofer system for deep vocal and bass effects. All magnetically shielded
Designed by Denmark acoustic expert, Peter Larsen V12 FineCone technology with perfect linear response
Individual amplifier unit with full front controls and includes wireless remote control
Technical Specifications:
Amplifier:
Output power: 84 Watt RMS
Power distribution: 12 Watt x 5 + 24 Watt
Harmonic distortion: < 0.3% 1 W 1 kHz
Frequency response: 30 Hz - 20 kHz
Signal/Noise ratio: > 70 dB
Separation: > 40 dB
Input sensitivity: 430 mV
Nominal impedance: 4 ohm
Speakers:
Tweeter driver type: 2.5" x 5
Tweeter rated power: 10 Watt
Subwoofer driver type: 6.5" - eAirbass
Subwoofer rated power: 40 watt
Interfaces:
Output: 6RCA sockets
Input: 6RCA sockets
Radio:
FM 87 mHz - 108m Hz
AM 522 - 1611 kHz EU, 530 - 1720 kHz South America & USA
Power:
Power supply: AC220 V - 240 V, 50 Hz, 380 mA
Fuse: T800mAL250V
Includes remote control
Package Contents:
Microlab FC730 subwoofer
Microlab FC730 satellites x 4
Microlab FC730 center speaker
3.5mm - 2RCA audio cable x 3
2RCA - 2RCA audio cable
User manual
