Beautifully crafted, the FC362W lets you listen to songs from your personal computer or notebook without cable. Enjoy wireless entertainment with 2.1 subwoofer speaker system advantage; deep bass and full range performances. Select your input choices or adjust the audio levels with Microlab's infrared remote control with ease.
Using state of the art 2.4 GHz technology for clear audio definition and clarity, FHSS technology allows wider availability bandwidth. Wireless multimedia audio data transmission direct from source to speaker system. This wireless design follows strict discipline in speaker designs to achieve perfect linear frequency response curve. Uncolored audio, precise position, and high resolution with Microlab's own eAirbass technology. It comes with 2.4 GHz ISM wireless technology.
Features:
2.1 subwoofer system with full range acoustic production and tower satellites
eAirbass design, Microlab own proprietory technology - Bass with natural depth and range
6.5" subwoofer system for deep vocal and bass effects. All magnetically shielded
Driver designed by Denmark acoustic expert, Peter Larsen V16 FineCone technology
Amplifier unit with 2.4GHz wireless technology
Source transmission via 2.4GHz USB dongle
Technical Specifications:
Amplifier:
Output power: 54 Watt RMS
Power distribution: 15 Watt x 2 + 24 Watt RMS
Harmonic distortion: 0.3% 1 Watt 1kHz
Frequency range: 35Hz - 20kHz
Signal/Noise ratio: > 75 dB
Separation: > 45 dB
Input sensitivity: 350mV
Fuse: T400mAL250V
Wireless Technology:
- 2.4GHz ISM band
- GFSK modulation
- up to 10m line of sight
- RF frequency hopping functions
- Audio format in 16bit, 48KHz sampling rate
- Low power consumption
Speakers:
Tweeter driver type: 2.5" x 2
Tweeter rated power: 15 Watt x 2, 4 ohm
Subwoofer driver type: 6.5" with eAirbass
Subwoofer rated power: 30 Watt 8 ohm
Interfaces:
Output: RCA sockets x 3
Inputs: 3.5mm stereo, and 2RCA sockets
Power:
Power supply: AC 220V - 240V ~ 50Hz, 200mA or AC100V - 120V ~ 60Hz, 460mA
Package Contents:
FC362W subwoofer
FC362W satellites x 2
FC362W amplifier with 2.4GHz technology
2.4GHz USB dongle
3.5mm stereo - 2RCA cable, 1.68m
Remote control
User manual
Dimensions:
Subwoofer dimension: 255 (W) x 255 (H) x 287 (D)mm
Satellites dimension: 96 (W) x 263 (H) x 110 (D)mm
Amplifier dimension: 75 (W) x 200 (H) x 200 (D)mm
Product net weight: 8.8 kg
Product Giftbox dimension: 434 x 406 x 304mm
Product Gross weight: 9.6kg
Export Carton dimension: 623 x 424 x 445mm
Export Carton gross weight: 20.4kg
