Enjoy your Meta Quest on the go with a hard protective case that takes up less space in
your bag, so you can experience VR and mixed reality anywhere. The thoughtful design
features an outer felt shell, soft hand strap and contoured inner compartments to keep
your gear organised and secure. It’s designed to fit your Quest 3/3S, two Touch Plus
controllers with lanyards or Active Straps, a charging cable and adapter. With its
lightweight construction, zip opening and rounded profile, this premium Meta accessory
makes it easier than ever to access your Meta Quest 3/3S and accessories wherever
you are.
