Go all in with enhanced comfort and battery life. This ergonomic strap increases balance and support with a quick twist of the fit wheel. The built-in battery doubles your playtime, letting you stay focused from the first step to the final mission.
Extend your play time
A built-in battery extends your play time between charges.
Maximise your comfort
A balancing design uses battery weight to lift the headset away from your face for a lighter feel.
Seamless compatibility
Engineered for use with official Meta Quest hardware and accessories (sold separately).
