Bring it with you or tuck it away. This lightweight case provides sturdy protection whether you're at home or on the go. The padded interior fits the Oculus Quest 2 headset.
Everything in its place
The Quest 2 Carrying Case fits your headset, two controllers, a charge cable, power adaptor and either Elite Strap perfectly.
Safe storage
A dual shell outer casing keeps your Quest 2 system out of harm’s way.
Portable protection
Contoured foam inner moulding absorbs rattles and bumps as you travel.
