The Maxtor M3 portable external hard drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity. The durable black design stands up to the rigors of daily use.
Maxtor M3 STSHX-M301TCBM - hard drive - 3 TB - USB 3.0
Hard drive - external (portable)
3 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Enclosure Colour
82 mm x 118.2 mm x 19.85 mm
236 g
3-year warranty
3 TB
USB 3.0
82 mm
118.2 mm
19.85 mm
236 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Software Included
AutoBackup, Secure Drive, SecretZone
Apple MacOS X 10.4.8 or later, Microsoft Windows Vista / 7 / 8 / 10
