Booming Stereo Sound
Mad Catz' F.R.E.Q.3 Stereo Headset is tough yet comfortable and lightweight, capturing sublime audio from games, movies, and music. Multiplatform GameSmart technology provides simplified setup and compatibility with a host of different devices. Boasting oversize 50mm speakers, intuitive on-ear controls, and a built-in microphone, the F.R.E.Q.3 is an exemplary headset for gaming and media consumption.
Extra-large 50mm Speakers with Neodymium Magnets
Employing the highest quality drivers available for use in commercial headsets - neodymium - the F.R.E.Q.3 Stereo Headset feeds high-fidelity audio through a pair of precision-balanced 50mm speakers for deep bass and crisp, undistorted highs. The skillfully engineered earcup design also helps block out distractions like excessive teammate chatter so you can focus on gaming at your best.
Integrated Microphone with Mute
An earcup-integrated mic gives you the freedom to chat with your teammates without the distraction of a fully extended microphone in your periphery. And when privacy is a concern, toggling the microphone mute button prevents your teammates from hearing anything you don't want them to.
Compatible with MP3 Players, Smartphones, and Portable Gaming Consoles
Use the headset's handy quick-release connector to instantly gain MP3 player compatibility and convert the Mad Catz F.R.E.Q.3 into portable headphones. Just swap out its PC connector cable for the included 3.5mm audio cable and then plug directly into your device. And if you have a smartphone*, you can even take voice calls using the earcup-integrated microphone.
*Supports Apple iPhone, Samsung, BlackBerry, and HTC handsets.
Tough Yet Lightweight Components
Built to the same exacting standards as the award-winning R.A.T. gaming mouse and constructed to survive the stress of LAN tournaments, the F.R.E.Q.3 couples comfort with sturdiness to accommodate prolonged gaming sessions. Lightweight components provide ample adjustability to give you a customized fit - and the cans even fold flat to support an around-the-neck resting position - all while bringing a level of durability previously unheard of in PC gaming headsets.
Easy to Locate On-ear Controls
Intuitive placement of all controls provides simple adjustability without the need to remove the headset. Mute the mic, tweak the volume, or answer an incoming call on your smartphone - without having to look at your device.
GameSmart Technology
Products featuring GameSmart technology operate seamlessly with a variety of different mobile devices. GameSmart enables near-universal compatibility with PC and Mac, as well as the latest generation of iPhone, Android, and Windows Phone handsets, and even tablets such as the Microsoft Surface.
When one product functions with a multitude of devices, you'll find comfort in knowing that a new device won't require yet another purchase. Used with your laptop, desktop computer, tablet or smartphone, the F.R.E.Q.3 is a go-to headset.
Compatible with M.O.J.O. Micro-Console for Android
Residing at the center of the GameSmart ecosystem, M.O.J.O. makes your favorite mobile games even better. M.O.J.O. delivers a powerful, console-quality Android gaming experience. See all the fast-paced action in breathtaking HD on your big-screen TV. Hear that catchy background music or those killer sound effects loud and clear, with support for 5.1-channel surround audio. The included C.T.R.L.R Mobile Gamepad enhances control of your in-game characters with the sticks-and-buttons gamepad design you know so well. Put it all together, and you've got a bigger, bolder, home-style version of the mobile games you love.
Courtesy of the 3.5mm headphone socket on M.O.J.O., the Micro-Console for Android is ready to accept the F.R.E.Q.3 Stereo Headset. Simply plug into M.O.J.O. to experience robust stereo audio for games and media.
Product Includes
- F.R.E.Q.3 Stereo Headset
- Mini-USB to Dual 3.5mm (pink and green) PC/Mac Cable
- Mini-USB to 3.5mm Cable
Minimum System Requirements:
- PC: Windows XP and Higher (all 32- and 64-bit versions)
- Mac: OS X 10.6.8 and Higher (Intel processor required
Product Specs
- Cable Length: 6.6ft/2m (PC/Mac), 3.3ft/1m (3.5mm)
- Cable Type: Braided
- Speaker Diameter: 50mm
- Ear Coupling: Circumaural (Over-ear)
- Magnet Type: Neodymium
- Frequency Response: 20Hz-20kHz
- Total Harmonic Distortion (THD): <1%
- Signal-to-Noise Ratio (SNR): 60 dB/V
- Resistance: 32 Ohms
