The Swan Surface Tablet Kiosk is the newest release from Compulocks. Elegantly designed with a white "swan-neck" sloping stand your Surface Tablet Kiosk bring a level of class to any setting.
The Surface Tablet stand is angled at 60 degrees for optimal viewing and sits 14 inches (35 cm) high and at the base is 7 inches (18 cm) wide. The enclosure rotates 90 degrees for smooth transition between landscape and portrait mode.
The wiring will come out the rear of the stand for a clean look and the base can be bolted to a counter top for security. It has a keyed lock for easy access to the your Surface Tablet when you need to take it with you or maintenance is required.
