            With more than 3x the reach of ordinary USB 3.x cables, Logitech Strong USB lets you separate self-powered USB 2.0 and 3.x peripherals and a host PC by up to 10 meters. The aramid-reinforced active optical cable is plenum-rated and Eca certified for safe operation and reliable performance to 10Gbps. By eliminating the need for USB extenders, Logitech Strong USB eliminates points of failure while reducing cost and complexity. Unlike typical USB cables that can break during or after installation, Logitech Strong USB is plenum-rated and Eca certified to pull through walls, above ceilings, and within standard ¾" conduit.
