Keep track of time, battery, and wireless reception with a glance or with silent, vibrating alerts. You remain focused on your presentation, not the clock
Up to 100-foot (30-meter) range
You'll enjoy the freedom to move around the room and mingle with your audience for greater impact. A reception-level indicator ensures you don't wander too far
Intuitive slideshow controls
Buttons are easy to find by touch. And the smooth contours feel great in your hand. You'll be in control from the first slide to the last
Plug-and-play wireless receiver
There's no software to install. Just plug the receiver into a USB port to begin. And when the show is over, you can store the receiver in the presenter
Make your point
Brilliant red laser pointer helps you get their attention-and keep it
You're in control
Navigate through your presentation with confidence with the intuitive slideshow controls
Work the crowd
The 100-foot (30-meter) range helps you make ordinary presentations extraordinary
Logitech Professional Presenter R700 presentation remote control
