Plug-and-play simplicity and a compact design make this optical mouse your perfect travel companion.
With easy setup, you just plug it into your USB port--it works right out of the box.
Compact design
The compact design makes it easy to slip the mouse into a bag and take it with you.
Optical tracking
You'll enjoy the smooth, accurate cursor control of optical tracking.
