A full-size, wireless laser mouse with more comfort and extra controls so you can do more, more easily.
A nice grip
With its contoured shape, soft rubber grips and handy controls, this full-size, wireless laser mouse M510 delivers the comfort and control you need to do more, more easily.
Two-year battery life
It practically eliminates battery hassles. An On/Off switch and smart sleep mode extend battery life, while an indicator light eliminates surprises.
Side-to-side scrolling plus zoom
The power is in your hands. You can scroll side-to-side in documents or zoom in and out of photos and spreadsheets with a flick of your finger.
Laser tracking
Laser precision means you'll enjoy smoother tracking on just about any surface.
Logitech Unifying receiver
The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse or keyboard--without the hassle of multiple USB receivers.
Programmable controls
You can configure the controls to make them to do exactly what you want like switching applications, opening browser windows or jump to full screen while watching videos.
Back/Forward buttons
Moving quickly through documents or browsing your favorite Web sites is a breeze, especially for right-handers-- with buttons conveniently located under your thumb.
