With hyper-fast scrolling, you control the pace. Fly through long documents and Web pages with a single flick. Or switch to click-to-click mode for precise, line-by-line navigation.
A nearly frictionless scroll wheel lets you fly through long documents and Web pages with a single flick. There's no holding you back.
Click-to-click mode
You get the control you need for precise, line-by-line navigation of lists, slides, images, and menus.
Scroll-mode switching
With the press of a button you can toggle between hyper-fast and click-to-click modes. The choice is yours.
1000 dpi laser precision
With this outperforms optical mice, you will experience smoother cursor control on virtually any surface.
Forward/Backward buttons
Do more with your mouse. Move backward or forward through Web pages or navigate your photo albums with ease.
Plug-and-play USB
Works right out of the box-just plug it into your USB port.
Logitech M500 - mouse - USB
Mouse
Wired - USB
Western Europe
Movement Detection Technology
Laser
Movement Resolution
1000 dpi
Scrolling wheel, soft rubber grip
1 x USB cable - integrated
Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Western Europe
Input Device
Wired
USB
Laser
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
Plug and Play
Software Included
Drivers & Utilities, Logitech SetPoint, Logitech Control Center
