From surfing the web to updating your Facebook - you'll be mousing on more surfaces thanks to Logitech optical. No delays, dropouts or hassles. The plug-and-forget nano-receiver keeps you connected with reliable wireless.
Enjoy precise clicking and pointing - on surfaces other optical mice can't handle - while navigating your favorite websites thanks to Logitech optical tracking.
Logitech 2.4 GHz wireless connectivity
You get the reliability of a cord with wireless convenience and freedom - fast data transmission and virtually no delays or dropouts.
Plug-and-forget nano-receiver
So small and unobtrusive, you can plug it into a USB port and forget about it. Plus, you can say good-bye to worries about broken or lost receivers.
Compact comfort
You'll enjoy more comfort and ease thanks to this compact mouse's hand-friendly, contoured design with soft rubber grips and a smooth scroll wheel.
Perfect for laptops and notebooks
No matter what type of computer you own - you can depend on your mouse to work like you expect.
Scrolling wheel, rubber side grips, battery indicator, on/off power switch, Logitech Unifying receiver, Logitech Advanced Optical Tracking
1 x AA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later, Windows 8
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
USB wireless receiver
Orientation
Right and left-handed
5 cm
9 cm
3.3 cm
86 g
Pink ivory
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 25 m
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
USB 2.0 Full-Speed
AA type
Alkaline
Installed Qty
1
Run Time (Up To)
1 year
