An iPad Air case that adjusts to you. Get comfy, Hinge holds iPad at any angle within a 50-degree range. iPad stays firmly in place until you decide to change it.
A smooth-gliding hinge makes the case flexible yet durable. Withstands angle adjustments time after time
Multi-angle stand - adapts to you
Hinge precisely sets to any angle within a 50 degree range and holds firmly once in place
Easy sharing
Flip the iPad case to instantly share your screen with coworkers, family or friends
Stylish fabric
Beautiful fabric perfectly fits your style whether you're at home or on-the-go
Essential Protection System
Precision engineered with state-of-the-art materials and cutting-edge manufacturing, Hinge protects iPad from accidental bumps, scratches and spills. Scratch protection for iPad enabled when case cover is closed
Camera, microphone and charger holes
Use the camera, microphone and charger without removing iPad from the case
Logitech Hinge - protective case
Protective case
17.56 cm x 1.45 cm x 24.48 cm
335 g
Material
Polyester
Light brown
17.56 cm
1.45 cm
24.48 cm
335 g
Material
Polyester
Light brown
Carrying Case
Protective case
Protection
Scratch-resistant, spill-resistant
Camera lens cutout, sleeping mode, port cut-outs, adjustable viewing angles
