Sharing, socializing, connecting with the people you care about - that's what makes a webcam different. And Logitech HD webcams are about sharing your life - but bigger, better, brighter, smoother. High-def yourself.
C310 HD Webcam gives you sharp, smooth video calling (720p/30fps) in a widescreen format. Automatic light correction for clearer, better conference calls
WIDESCREEN HD 720P VIDEO CALLS
Crisp HD 720p/30 fps video calls with 60° diagonal field of view and auto light correction. Compatible with popular platforms including SkypeTM and Zoom
MONO NOISEREDUCING MIC
The built-in noise-reducing mic makes sure your voice comes across clearly up to 1.5 meters away, even if you're in busy surroundings
AUTO-LIGHT CORRECTION
C310's RightLightTM 2 feature adjusts to lighting conditions, producing brighter, contrasted images to help you look good in all your conference calls
FIRM MOUNTING OPTION
The adjustable universal clip lets you attach the camera securely to your screen or laptop, or fold the clip and set the webcam on a shelf
ESSENTIAL TOOLS. BETTER WORK
Simple, powerful tools that deliver real work victories - even at home. Complete your setup with the right keyboard, mouse, headset, and webcam for better typing and navigation, plus superior audio and video-so you can conquer just about any task from home
Logitech HD Webcam C310 - webcam
Webcam
Audio
Yes: built-in microphone
Wired
Camera
Max Resolution
1280 x 720
Motion Detection
USB 2.0
1 - USB cable - 1.5 m
RightSound technology, RightLight 2 technology, snap-shot button, Motion Detection Technology, 720p HD video calls, noise reduction, Skype compatible
Webcam
Audio Support
Wired
EMEA
Camera
Max Digital Video Resolution
1280 x 720
Motion Detection
Computer Interface
USB 2.0
1 x USB cable - 1.5 m
Software Included
Drivers & Utilities, Logitech Video Effects, Logitech Vid HD
Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits), Windows 8
System Requirements Details
Windows Vista/7/8 - 1 GHz - RAM 512 MB - HD 200 MB
