The magic touch
Your Harmony advanced universal remote turns on the right devices, in the right order--with one touch.
You've got a touch of luxury thanks to 3.5-inch, full-color touch screen and one-touch activity controls with the Logitech Harmony 1100 Touch Screen Remote Control, it is the perfect complement to your sophisticated living room. Put a brilliant, 3.5-inch, full-color touch screen in your hands. You'll be able to turn on everything you need with just one touch. And you can customize the controls to get the commands you want, when you want. It's like no remote you've ever used before.
One-touch activity controls - Your favorite entertainment is just one touch away
It's as easy as one. (No two or three needed.)
Say good-bye to cheat sheets. Everyone in the family can select what they want to do--such as "Watch TV"--and your Logitech Harmony remote does the rest.
You just want to watch a movie. But you're digging through a drawer with a pile of remotes in it. When you do find the remotes it's going to take (usually at least three), it takes you another few minutes to press the right buttons in the right order. And if you make a mistake--or have to explain it to your parents or your babysitter--well, then you're waiting even longer.
One-touch activity-based control is the answer.
One remote. One touch. That's all it takes to watch a DVD, listen to the radio, watch TV, or play a game. With a Harmony remote with one-touch activity-based controls, your whole family (and the babysitter) can easily turn on the entertainment they want--without any help.
Simple to set up
So just how do you get your remote to do that? Our online software makes it easy.
To get started, use the included USB cable to plug your remote into your computer. Then simply enter the make and model numbers of your components and answer questions about your entertainment setup--like what components are needed for different activities, how everything is connected, and what input is needed for what. That's it.
Your Harmony remote is compatible with more than 225,000 devices from 5,000+ brands right away. If you've got it, it's probably in our database--no extra programming needed.
And if you do hit a snag in getting everything set up, our helpful online support and our knowledgeable customer service staff are ready to help you.
3.5-inch full-color touch screen
You can access the most-used buttons with one hand or two--and it's backlit so you can see your icons even in the dark.
Works with 225,000+ devices
Support for 5000+ brands and 225,000+ devices, so you know it will work with what you have today and what you'll add tomorrow.See how your home-entertainment setup would work with Harmony.
RF wireless capability
You can control devices you can't see--like a stereo in a closed cabinet.when you add a Logitech® Harmony RF Extender (sold separately).
Customisable commands and icons
You choose which commands you want on screen and when--giving you complete control over your entertainment system.
Replaces up to 15 remotes
You can control your home-entertainment devices with one remote--reducing clutter and complexity in your living room.
Rechargeable
Your remote recharges in its base station so you won't be looking for batteries when you want to be watching TV.
