Play console ports with their native-style controller or adopt a more relaxed position while enjoying PC games. F310 is easy to set up and use with your favorite games thanks to XInput/DirectInput -the two most common input standards
Steam Big Picture
Pair the F310 with Big Picture and navigate Steam, surf the web, play games and more from the comfort of your couch. Bring your entire library of Steam games to the living room, grab your F310, sit back, and enjoy
Familiar console-like layout
Your instincts will guide your actions over the familiar layout. You'll be off and gaming in no time. Crafted for a console-like control experience and innovated from traditional design, F310 fits like a glove
Exclusive 4-switch D-pad
Standard D-pads rest on a single pivot point, resulting in mushy control. The D-pad glides over four individual switches for a more responsive, tactile feel
Works with Android TV
Our game controllers work well with Sony Android TV s. With the controller switch in XID mode, our console-like layout will give you the edge as you compete. Smooth curves and contoured rubber grips provide long, comfortable play sessions. Standard Android TV controls - provided through the Logitech Logo button on the gamepad together with the Back key on the controller - allow you to navigate your Android TV seamlessly. Learn how to use Logitech gamepad buttons with Android TV
Easy to set up and use
Change the standard commands or adapt F310 for play with an unsupported title, using Logitech profiler software. Buttons and controls are fully programmable and can even mimic keyboard and mouse commands
1.8 meter cord
Relax a comfortable distance from the monitor or do a victory dance. Preferably both
Comfortable grip
Enjoy long, comfortable play sessions thanks to smooth curves and contoured rubber grips
Logitech Gamepad F310 - gamepad - wired
Gamepad
Wired
Buttons Qty
10
Controls
Dual analogue sticks, Back button, Start button, Home button, 2 analogue triggers, 2 shoulder buttons, 4 action buttons, 8-way D-pad
Rubber side grips, fully programmable buttons, sports mode
3-year warranty
PC
Gamepad
Wired
Buttons Qty
10
Controls
USB
