Level up without being tied down - in 7.1 surround sound
Gaming-grade wireless gives you a lag-free, interference-resistant connection with a range of up to 12 metres (40 feet)* - so nothing stands between you and victory. 7.1 surround sound powered by Dolby® technology delivers a detailed, positional soundfield that lets you hear your opponents before they see you. You'll have total command over music, voice morphing, chat clients and more with three programmable G-keys. And a memory foam-lined headband fends off fatigue, while plush ear pads ease pressure points and seal out unwanted noise.
Let nothing stand between you and victory with a lag-free 2.4 GHz wireless connection that lets you move freely away from your computer. Explosions, footsteps, incoming fire, passing vehicles, team-member commands - you hear it all in 7.1 surround sound. With three programmable G-keys, you've got one-touch control over in-game elements like music, chat and voice morphing.
2.4 GHz wireless connectivity
Designed for a lag-free, interference-resistant connection with a range up to 40 feet (12 meters)*--so nothing stands between you and victory.
7.1 surround sound
Advanced Dolby® technology delivers a detailed soundfield that lets you hear your enemies before they see you.
Three programmable G-keys
You've got one-touch command over music, voice morphing, chat clients and more
Adjustable, memory foam-lined headband
Creates a personalized fit to fend off fatigue.
Plush, noise-isolating ear pads
Ease pressure points and seal out unwanted noise.
Laser-tuned drivers
We analyze each acoustic element--magnet, coil and diaphragm--to optimize the drivers and pinpoint unwanted distortion, so you hear only rich, clear audio.
Noise-canceling mic with auto-mute
The microphone reduces annoying background noise for clear, intelligible voice commands, and automatically mutes when you rotate it up and out of the way.
Microphone mute light
The microphone tip glows red when muted.
On-ear audio controls
Adjust volume and microphone mute on the fly--don't fumble for controls in the heat of battle.
Painless recharging
Recharge using the universal micro-USB cable--even while you're still playing. When charging is complete, wrap up the cable inside the charging base.
Batteries built for battle
With up to 10 hours of battery life, this headset can get you through the most epic gaming sessions.
Adjustable audio settings
Tweak surround sound settings and equalizer levels using the included software.
Real-time voice morphing
You can select from six voices-- troll, mutant, alien, giant, cyborg and space squirrel.
Plug-and-play setup
Don't worry about unplugging or rearranging your speakers. Just plug the wireless adapter into the charging base or a USB port and you're ready to play.
