The game doesn't need to stop when it's time to recharge. G700s charges during play over its standard Micro-USB cable. To power up, switch seamlessly from wireless to data-over-cable connection over a standard Micro-USB cable. The standard AA NiMH batteries charge up while you stay in the game.
Be confident that your every command is executed as quickly as possible. G700s maintains a consistent 1 ms report rate, whether over 2.4 GHz wireless or connected by USB. Up to eight times faster than a standard USB mouse, G700s captures your moves as fast as you can make them.
