With 20 buttons, the Logitech G600 MMO gaming mouse is the most customizable and easy to use mouse specifically designed for mastering your favorite MMOs.
Pre-configured for optimal MMO use right out of the box. G600 includes three primary buttons, 12 thumb buttons, a clickable scroll wheel that tilts and a G-switch to double down and dominate. Use optional Logitech Gaming Software for full programmability and customization
Dual-dish thumb panel
Put immediate access to all 12 primary MMO skills under your thumb. The unique dual-dish design of the thumb panel was developed with direct input from both MMO gamers and leading MMO game developers. Field-testing led to two carefully positioned sets of six buttons, helping to reduce both learning time and action timings. And the actuation force is carefully tuned to minimize misclicks
G-shift button
Use the G-Shift button to double the total number of customizable functions. In its default setting, holding the G-shift button down activates a second function to each G-key. Or set G-Shift to temporary change DPI for extra cursor precision
Custom-color backlighting
Locate keys in any room with custom backlit keys. Choose 1 out of 16 million colors and assign a unique color to each profile, profile mode, and mode style in the same game. You can tell, without looking down, which mode you're in to ensure your setup is optimized
Custom-color lighting
Customize the thumb panel lighting for a clear visual reference of up to 3 active profiles and 3 different sub modes. Choose 1 out of 16 million colors and assign a unique color to each profile, profile mode and mode style in the same game. Make colors pulse on-and-off or cycle continuously
Onboard memory profiles
Program up to three profiles for individual players or games (keyboard macros and DPI settings), and bring your game to other PCs with no software required
On-the-fly dpi switching
Quickly shift DPI levels, from pixel-precise targeting (200 DPI) to lightning-fast maneuvers (up to 8200 DPI), all with a single button press located behind the scroll wheel, or by reassigning the ring-finger button for temporary shifts in cursor speed while held down
Durable build
Gaming conditions torture typical mice. All three primary buttons are rated to a 20 million-click lifespan. Low-friction polytetrafluoroethylene feet are tested to last an amazing 250 km. G600 is designed to endure
Naturally contoured grip
With a natural contoured grip designed for maximum comfort and every button carefully positioned to reduce click fatigue while avoiding accidental actuations, you'll always be the last gamer standing
Gaming-grade laser
When the difference between MVP and also-ran is measured in pixels, laser sharp sensitivity pays off. G600 uses a gaming-grade laser that delivers precision at any hand speed and works across a wide range of surfaces to register even the most subtle hand movements
Braided USB cable
With a cloth wrapped, durable 2 m (6.5 ft) USB cord, your G600 mouse comes with a hook-and-loop cable to keep things tidy and ready to play
1-millisecond report rate
Be confident your every command is executed as fast as possible. The 1000 Hz report rate is up to eight times faster than a standard USB mouse. G600 captures your moves as fast as you can make them
Low-friction feet
The low-friction polytetrafluoroethylene feet eliminate friction on nearly any surface for smoother motions, precise cursor movements and improved accuracy
Easy-to-use setup software
Use the optional Logitech Gaming Software to perfectly match its commands to your favorite games. Simple drag-and-drop settings allow you to customize button and tracking profiles for any game you play. Or, use pre-configured customizations with automatic game detection. Learn more about Logitech Gaming Software
Logitech Gaming Mouse G600 MMO - mouse - USB - black
Mouse
Wired - USB
Orientation
Right-handed
7.5 cm x 11.8 cm x 4.1 cm
133 g
Movement Detection Technology
Laser
Buttons Qty
20
Movement Resolution
8200 dpi
Performance
30 G maximum acceleration, 1 ms response time, 1000 reports per second, 160 inches per second, realtime sensitivity switching 200 - 8200 dpi, 11.25 megapixels per second
