The Logitech G35 Surround Sound Headset features game-changing immersion with 7.1 surround sound powered by Dolby technology. Victory never sounded so good.
You'll hear up to seven discrete channels of audio data plus the Low Frequency Effects (LFE) channel-known as 7.1 surround sound. Dolby Headphone software perceptually positions each channel in the correct location to reproduce multi-channel content the way developers intended
Three programmable G-keys
You've got one-touch control over in-game elements like music, hotkey macros, and more
A sound advantage
G35 is powered by Dolby Headphone to create an immersive 360-degree sound field that lets you hear what you can't see. Footstep. Enemy fire. Sirens. Because when you have eyes in the back of your head, you win
Mute light
A glowing red indicator light provides a visual cue to your audio status and keeps you informed when the mic is muted
Full-speed, all digital USB
In-game sound isn't an effect. It's a critical component of game play. Our USB headphones surround you with aural information. The sound is crisp and clear, and the jack on your sound card stays open for desktop speakers
Logitech G35 Surround Sound Headset - headset
Headset - 7.1 channel - wired
Recommended Use
Computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Surround Sound
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 90 dB
Impedance
32 Ohm
Microphone Operation Mode
Mono
Controls
Mute, volume
Microsoft Certification
Compatible with Windows 7
3-year warranty
Recommended Use
Computer
Audio Output
Full size
Wired
Sound Output Mode
Surround Sound
Frequency Response
20 - 20000 Hz
Sensitivity
90 dB
Impedance
32 Ohm
Diaphragm
40 mm
Magnet Material
Neodymium
In-Cord Volume Control
Microphone
Mono
Sensitivity
-42 dBV/Pascal
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional
Remote Control
Controls
Mute, volume
Connector Type
USB
Cable Details
Headset cable - 3 m
