The cloth surface of G240 provides ideal surface friction for low DPI gaming, improving mouse control and precise cursor placement. Consistent surface texture can improve sensor performance, especially when used with Logitech G gaming sensors. And the soft rubber base maintains stability without sacrificing comfort.
Whether using an optical or laser mouse, G240 can give gamers access to enhanced sensor accuracy and precision. G240 uses a surface texture comparable to the optimal testing environment for Logitech G mice.
At just 1mm thick, G240 maintains a low profile. The soft fabric improves comfort as the wrist moves back and forth across the mouse pad's edge.
With a flexible cloth construction, G240 rolls up for easy transport and lies flat when you're ready to play. Protect the mouse pad when you take it to LAN events using the hexagonal packaging.
