You can dig in, take command, and stay informed with game-changing comfort and control. Or an LCD gameboard that gives you game-changing comfort and control - wherever you go.
G13 includes 25 programmable G-keys that simplify complex actions by allowing you to configure up to 75 unique functions across three different modes with three macros per key. With G-keys, instant access to a variety of customizable functions is just a click away. Harness the power of G-keys to configure single key presses, complex macros or intricate LUA scripts on the fly. Quickly simplify actions to stay immersed in your game and never lose a step. Learn more about Logitech Gaming Software
Backlit GamePanel LCD
Use the GamePanel LCD to extend your cockpit with mission critical data such as real-time game stats, system information, VoIP communication data and game timers. Add community-developed applets to work with GamePanel or develop your own. Plus, the display backlighting matches the custom-color backlit keys
Programmable mini joystick
Maneuver quickly and easily with a customizable mini joystick located conveniently under your thumb
Contoured game board design
Naturally contoured design that follows the natural shape of your hand and fingers for increased comfort during long gaming sessions
Custom-color backlighting
Locate keys in low-light or total darkness with custom-color backlit keys. Choose from 16 million colors and assign a unique color to each profile, profile mode and mode style in the same game. You can tell at a glance which mode you're in and ensure your setup is optimized
Onboard memory profiles
G13 saves your profiles onboard, so you won't lose your settings even when you bring it to other PCs. And custom profiles are still active even if you're not running Logitech Gaming Software
Multi-key input
During the heat of battle, you need to simultaneously run, strafe, select a weapon and open a door. N-key rollover multi-key input on G13 means complex moves are executed exactly right every time. Press any combination of keys and see each registered together. And full anti-ghosting means you never need to see a command you didn't intend
Solid, stable design
Engineered for maximum intensity. The gameboard base contains 650 grams of stabilizing weight and sturdy support feet. G13 stays where you put it
Easy-to-use setup software
Use the optional Logitech Gaming Software to perfectly match its commands to your favorite games. Simple drag-and-drop settings allow you to customize button and tracking profiles for any game you play. Or, use pre-configured customizations with automatic game detection. Learn more about Logitech Gaming Software
