Careful attention to materials and finish means CREATE is both beautiful and protective. Custom-sculpted curves and precision-formed anodized aluminum provide structural integrity to protect your device on the inside.
Edge-to-edge layout of well-spaced keys helps ensure familiar laptop-like typing. Mechanical scissor keys are tuned for productivity with 1.3 mm key travel - an optimal depth for comfortable and responsive typing. A full row of iOS shortcut keys put iPad Pro controls at your fingertips - change volume, language and more - all without leaving the keyboard
THE POWER OF SMART CONNECTOR
CREATE comes with the new generation of connectivity - Apple Smart Connector. This means you never need to charge your keyboard, it will source power directly from your iPad Pro. No more charging cables or worrying about battery life. Smart Connector also means that Bluetooth pairing is a thing of the past. Just set iPad into a typing position - as soon as the two points of the Smart Connector touch - you are ready to type
TYPE AWAY, DAY OR NIGHT
CREATE keyboard case has backlit keys with adjustable light levels. Choose from several backlight levels to get exactly the intensity of light you need. To manage the power smartly, CREATE can detect activity – 8 seconds after the last keyboard stroke, the keyboard will go into sleep mode, turning the backlighting off to save the iPad Pro battery
TYPING AND VIEWING MODES
Two different angles make the most of the beautiful iPad Pro screen whether you're writing your novel, watching videos, playing games, or using Apple Pencil to take notes
FRONT AND BACK PROTECTION
CREATE is the iPad Pro case that carefully envelopes your iPad for all-around protection against bumps, scratches and spills. Outer technical fabric is soft to touch, yet resistant to spills and can be wiped clean. On the inside, a lightweight frame and a keyboard module provide structural integrity without weighing down your iPad Pro
Logitech CREATE - keyboard and folio case - UK - black Input Device
Keyboard and folio case
Backlit
Apple Smart connector
Wired
Localization and Layout
Hot Keys Function
Volume, search, brightness, home screen, backlight control, iPad sleep mode
Black keyboard, black case
31.5 cm x 23 cm x 1.99 cm
725 g
Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
Backlit
Hot Keys Function
31.5 cm
23 cm
1.99 cm
725 g
Carrying Case
Transformable into a stand for typing or viewing video, sleep/wake function, water repellent
