CONNECTS TO VIRTUALLY ANY Bluetooth WIRELESS DEVICE
Whether you're a Mac computer addict, use solely Windows or Chrome OS , favor a Windows or Android tablet or switch between them, the M535 simply works
COMPACT, MOBILE DESIGN
Slip M535 mobile mouse into your bag or pocket so you have it anywhere you need it
CURVED SHAPE WITH RUBBER GRIP
Comfortable and supportive for your hand, to keep you going for as long as you like
SMART CONTROL AND EASY NAVIGATION
The convenient navigation button and tilt wheel put control in the palm of your hand. Download Logitech Options software to enable gesture support on Windows and macOS
Decades of Design Excellence
We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
Logitech M535 - mouse - Bluetooth 3.0 - blue
Mouse
Wireless - Bluetooth 3.0
Blue
6.11 cm x 10.05 cm x 3.3 cm
82 g
Movement Detection Technology
Optical
Movement Resolution
1000 dpi
Rubber side grips, battery indicator, scrolling wheel
AA type
Android 3.2 (Honeycomb) or later, Apple MacOS X 10.8 or later, Google Chrome OS, Microsoft Windows 7 / 8 / 10 or later
Mouse
6.11 cm
10.05 cm
3.3 cm
82 g
Blue
Input Device
Wireless
Bluetooth 3.0
Max Operating Distance
Up to 10 m
Optical
Movement Resolution
1000 dpi
1 AA battery
AA type
Run Time (Up To)
10 months
