Let's turn your iPad into a laptop. Comfortably-spaced keys. The ideal, concave, key shape. A familiar layout you won't have to 're-learn.' And a dedicated row of speedy iOS shortcuts
Designed for typing and tapping
The keys have plenty of room, yet the screen is still right at your fingertips for fluid interaction. iPad doesn't bounce or tip over when you tap. It's just one idea after another
Smart power management
A mobile, Bluetooth keyboard should have enough power to last, and smarts to conserve. We like that idea.- iPad and Type+ both automatically turn on when you need them and off when you don't - Get up to 3 months of battery life on a single charge Based on average use of two hours per day
Two cases in one
It's a keyboard case when you need to type and not when you don't- Typing mode sets ideal viewing angle for both typing and screen interaction. Typing mode automatically turns keyboard on. - Lay-flat reading mode automatically turns keyboard off
Lightweight, but serious about protection
The idea of incredibly thin and light also means protection against bumps, scratches and spills. Convenient, huh
Logitech Type+ - keyboard and folio case - UK - carbon black Input Device
Keyboard and folio case
Bluetooth
Localization and Layout
Carbon black
25.59 cm x 18.34 cm x 1.81 cm
405 g
Bluetooth
Max Operating Distance
Up to 10 m
25.59 cm
18.34 cm
1.81 cm
405 g
Carrying Case
Scratch-proof, transformable into a stand for typing or viewing video, spill-resistant, dual-mode positioning, sleep/wake function, SecureLock system
